7.3 & 6.9 question
Old Dec 14, 2006 | 03:42 PM
lost450's Avatar
lost450
7.3 & 6.9 question
Can anyone clear up what year models the 6.9, 7.3, 7.3 turbo, and 6.0 power stroke were and are produced. Also did international make all of them or just the 6.0 and 7.3. Im new and ignorant to most of this stuff. Please clear all this up thanks.
Old Dec 14, 2006 | 05:12 PM
lost450's Avatar
lost450
ok i took the time and looked at the other parts of this forum and answered my own question.
Old Dec 14, 2006 | 09:04 PM
IHdieselfan's Avatar
IHdieselfan
well just to clairify
- 6.9l old glow plug system-'83 to '86
- 6.9l new glow plug system-'87 only
-7.3l idi non turbo-'88 to '92
-7.3l idi turbo-'93 to '94.5
-7.3l heui turbo-'94 to '96
-7.3l heui turbo innercooled-'99 to 2003
-6.0l-2003 on
23 years of international harvester (to me it will always be IH)diesels in ford trucks.
only if we could have the DT466 as an option
Old Dec 14, 2006 | 10:29 PM
Dave Sponaugle's Avatar
Dave Sponaugle
7.3 heui turbo 94.5 to 97 (DIT)(Power Stroke)
Old Dec 15, 2006 | 08:33 AM
lost450's Avatar
lost450
OK so whats the difference between heui and idi turbos? And a 94' 7.3 does have a some type of turbo?
Old Dec 15, 2006 | 09:29 PM
Dave Sponaugle
HEUI is the injection system used on the Power Stroke engine which is also called Direct Injection Turbo (DIT). All Power Stroke engines were equipped with a turbo.
They are also electronically controlled by a computer, fly by wire. The throttle pedal is attached to a rheostat that tells the computer to tell the engine you want to go faster. To get more power, you reprogram the computer with a chip.
IDI - InDirect Injection the fuel is sprayed into a precombustion chamber which spreads into the cylinder area. The IDI is mechanically controlled and has a throttle cable that attaches the throttle pedal to the injection pump. To get more power, you add air and adjust the IP.
In 94 there were three 7.3 engines available.
The 7.3 NA IDI.
The 7.3 turbo IDI
The 7.3 DIT Power Stroke
The bottom two had turbo's the top one did not.
