1989 302
Old Dec 13, 2006 | 11:37 PM
tradecki's Avatar
tradecki
I am new to this and would like to know if the F-150 302 is the same as the mustang 302 other than the intake
Old Dec 14, 2006 | 07:52 AM
Conanski's Avatar
Conanski
Yes and No. Different intake as noted, but the HO also gets a healthy roller cam, and from '89 on uses a sequential mass air injection system versus the trucks speed density batch fire. The HOs from the pocket rocket era, '87-'92 also had forged pistons, which is a benefit for adding a blower or spray, but otherwise makes no performance difference. The block and heads are identical though, so you can make a truck motor into a HO by swapping on/in parts.
Old Dec 14, 2006 | 10:20 AM
Lumpy87's Avatar
Lumpy87
I think they also have different timings therefore different cams. I believe the crank is the same though.
Old Dec 14, 2006 | 11:40 AM
Talyn's Avatar
Talyn
Roller cams are diff.
You cannot have a steep climb on a solid cam as compared to a roller cam.
Running rollers on a solid cam has no benifit whatsoever.
The HO's have a different fireing order also. I think. not 100% sure on that one.
Old Dec 14, 2006 | 05:07 PM
Lumpy87's Avatar
Lumpy87
I meant firing order not timing. It shouldn't make a diffference as long as you keep the engines original injector harness and computer.
There may be differences in the serpintine belt and accessories. I know I had to specify which direction my fan rotated when replacing the fan clutch.
Old Dec 14, 2006 | 11:24 PM
Ben-jamin's Avatar
Ben-jamin
i know everything outside the engine is different, oilpan & pick-up, all the manifolds, front bracketry, timing cover,water pump, covers but; firing order is the same
Old Dec 15, 2006 | 02:17 AM
KDPate's Avatar
KDPate
Not quite concerning the firing order. Non-HO 5.0 engines used the old 289/302 firing order while the HO 5.0 engines used the 351W firing order. 85-up 302 blocks do have provisions cast in for the roller cam/valvetrain if someone wants to adapt it in.
MER
29
Apr 17, 2008 02:51 PM
pac_302_xlt
22
Apr 10, 2005 06:02 PM
winfordr
Dec 16, 2001 07:50 PM
William
Mar 22, 2001 02:08 PM
hotrodford_88
Dec 15, 2000 11:01 PM
