Headlight Upgrade?
Old Dec 13, 2006 | 11:31 PM
Boltgunner's Avatar
Boltgunner
Headlight Upgrade?
Anyone have some input on a selection for a headlight for my '76? Brand, model? Thanks!
Old Dec 13, 2006 | 11:49 PM
Mil1ion's Avatar
Mil1ion
I put the Bosch system in mine back in 1980.They were $115.00 at that time.
I saw them in Canadian Tire for $89.95
H4 bulbs 80w/100w
I will be doing the upgrading relay system this spring.
The pattern of light is most important.
The Bosch have this pattern
___/ ____/
Most others are like this which wastes light
>-----< >-----< (extend the ears higher)
Old Dec 14, 2006 | 04:17 AM
Alvin in AZ's Avatar
Alvin in AZ
Originally Posted by Mil1ion
I put the Bosch system in mine back in 1980.They were $115.00 at that time. I saw them in Canadian Tire for $89.95
H4 bulbs 80w/100w
___/ ____/
A couple years ago I put in a pair of Silvania Silver Stars. <shrug>
Don't know anything about them really, just whiter than their other round, halogen sealed beams.
That pattern is cool Dennis unless the frontage road goes along next to the freeway. Both been bothered-by and bothered-others in that situation with ordinary low beams.
What do you think? :)
Alvin in AZ
Old Dec 14, 2006 | 06:49 AM
cujo8's Avatar
cujo8
H4 bulbs 80w/100w
___/ ____/
What does this headlight upgrade kit consist of? These prices seem high if it's for a couple of headlights, but I have to admit I don't know much about this subject.
Old Dec 14, 2006 | 08:46 AM
Dave Severson's Avatar
Dave Severson
I got a set of tri-bar red dot headlight conversions with bulbs off of eBay for $70.00 plus freight. Man, they are so much better then the originals there is absolutely no compaison.... Just some of the cops don't like the red dots, so being the law abiding guy that I am I ordered a set of blue dots!!!!!!!
Old Dec 14, 2006 | 11:13 AM
1975Ford's Avatar
1975Ford
I installed the headlight relay upgrade, listed at this FTE Article section.
Run heavier guage wiring, install relays, and fuse panel.
It made a big difference in the headlight brightness.
Also the parking lights are brighter because they have more electrical power, due to the headlight system not running the headlights, and they are now on their seperate system.
Here a picture of the headlight relay system (aka blaster pack) - https://www.ford-trucks.com/user_gal...132496&width=0
I ran extra ground wires thru out the engine, frame, and body.
This also helps all the electronics.
Old Dec 14, 2006 | 09:25 PM
Boltgunner's Avatar
Boltgunner
Wow, cool wiring! What is this relay deal all about anyway?
Old Dec 14, 2006 | 09:47 PM
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
Silvania Silver Stars are what I want to put on my '76
Old Dec 14, 2006 | 09:52 PM
1979f_100's Avatar
1979f_100
They don't last long. My dad ran them on his Peterbilt, did a lot of night driving too mind you, and they would only last about 2-3wks at the time
Old Dec 14, 2006 | 10:12 PM
1975Ford's Avatar
1975Ford
Boltgunner, here is an informative thread - https://www.ford-trucks.com/forums/5...ght=head+light .
I heard the same thing about those aftermarket bright head lights, they burn out quickly and they are expensive.
I found the ground straps at the pick n pull. They use these straps on the 88-97 years ford trucks in the engine compartments.
Old Dec 14, 2006 | 10:57 PM
solidrunner's Avatar
solidrunner
I have Bosch H4 housings with 7000K HIDs in my truck. Once you get HIDs you'll never go back.
Old Dec 15, 2006 | 02:07 AM
Mil1ion's Avatar
Mil1ion
Ford in their infinite wisdom runs full power to the headlights thru the headlight switch.... This causes the circuit breaker to heat up and eventually cause flickering headlights.
GM uses the relay system:
with this system: power from the headlight switch trips the relay so
full-power from the Battery powers the headlights instead.
Volvo uses it and many other car companies.
It's the only way to go as your headlights efficiency rises as well.
Thus..... Brighter Brights
Bosch Hedlights pattern can be seen here...1/2 way down page.
http://www.humanspeakers.com/audi/headlight-aiming.htm
Old Dec 15, 2006 | 02:43 AM
Torque1st's Avatar
Torque1st
Posting Legend
Use fuses for the brights but use a circuit breaker for the low beams. You never want to be out of headlights because of a blown fuse. That is why the headlight switch has a circuit breaker.
Old Dec 15, 2006 | 09:12 AM
beartracks's Avatar
beartracks
Good point on the breaker. Auto reset might be a good idea.
Old Dec 15, 2006 | 10:01 AM
arctic y block's Avatar
arctic y block
Beartracks luv your Avatar
