hard starting 300
Old Dec 13, 2006 | 04:47 PM
Dirtmann's Avatar
Dirtmann
hard starting 300
my 300 is still hard starting and misses when accelerating under 2000 rpm (not as bad over 2000), shows system pass codes, I can get it to start if I advance the timing. fuel press shows ok and i have replaced many sensors including injectors and press regulator, now has a rebuilt dist. can fuel pumps show ok and cause this? I plan to drive the truck some to see if any codes show up,looking for any help, THANKS
Old Dec 14, 2006 | 05:53 AM
Dirtmann's Avatar
Dirtmann
Shows 96 code after test drive. has duel tanks with high pressure pump on frame.
