I was driving to get a trailer yesterday doin about 65 and all of a sudden the wotor started to shake real bad, lost some power,and it sounded like the motor was exhausing through the intake! So I pulled off to the side for a minute it sounded normal when idling, so I tried to take off easy and when I got to about 1800 rpm it did it again. Not good cause I was about 150 miles from home. I knew it was time for an oil change and thinking that maybe the combo of dirty oil high rpm might be causing the valves to float so I limped it to a oil change place and had it changed I put in 3 quarts of lucas oil treatment, and 7 of oil. I drove back home with no problems whatso ever. and the last 50 miles i was hard on it floored it and held it there with no problems. But today after about 275 miles with no problem it did it when I was going up a hill towing a 4000 lb trailer on the highway I was doin 62 and didn't give any skinny pedal when I was goin up I was just letting the truck slow down it was about to down shift. and it did it so I pulled to the side and sat for about 30 seconds and then it was fine (it idles normal still) I drove another 40 miles and it did it again under load,but lower rpms. and I was able to drive home normal after that. There no real hills by me just overpasses and small hills i'm in illinois remember. What do u guys think? weak valve springs, or bad guides? help I will lose about $250 a day if it goes down. Im pricing new truck now just in case.
a fuel filter could cause this? really? maybe a bit more black smoke when it did it , but not much. Temps are normal. I'll change my filter tomorrow it's got maybe 5,000 onit.
It might be a fuel thing like you say, but it hasn't done it since I changed the oil and added all 3 qts. of lucas. It was doing it on both tanks full and half. I'm not gonna address it anymore if the deal on the new truck goes right. I would fix and keep it till next fall, but it is under powered for what I do, and gets 6 to 8 mpg towing. the 15.5 empty is cool, but I can make $40 more a delivery with a psd I do about 3 deliverys a week on average. I planned on paying off my car in 6 more months, and knocking the trailer down some to but I don't have the credit to have two car notes, and my travel trailer note, So my Vw has to go now I guess.
