rpm guage
Old Dec 13, 2006 | 06:52 AM
knapikmichael's Avatar
knapikmichael
rpm guage
my rpm guage in my truck reads no rpms until i give it gas other than that it sits at zero what happened
Old Dec 13, 2006 | 07:21 AM
PLC7.3's Avatar
PLC7.3
The dead tach sender should/would send the automatic trans into a "failure management mode" (limp mode) with harsh engagements and firm shift feel, and an abnormal shift schedule. It has no effect on a manual trans only the Tach readings.
Replace the tach sender on the oil fill housing a big 1" nut with 2 wires. Ford only part Engine RPM sensor E5TZ-17B384-A about $50. You can remove and clean it but usually changed later too. You can test it too, hold it in the air away from ferrous metal, using an ohm meter lead on each wire you need DC resistance between 2000-3000 ohms.
