Injectors
Old Dec 12, 2006 | 08:17 PM
kcw12's Avatar
kcw12
Injectors
My truck has about 200k on it. The injectors are factory and never been replaced from what i can tell. Do they have to be replaced periodoically.
Old Dec 13, 2006 | 06:09 AM
bilder12's Avatar
bilder12
if its running smooth, doesnt seem to have a miss in a cylinder and isnt leaking fuel from the topside ... DONT MESS WITH IT.
keep using fuel additive for lubricating the fuel system in each tank full.
Old Dec 13, 2006 | 08:40 AM
kcw12's Avatar
kcw12
It isnt running smooth. Acts like its got a miss on it.
Old Dec 13, 2006 | 10:22 AM
Ben-jamin's Avatar
Ben-jamin
if you break the line loose at each injector you can locate the offending cylinder, then just pull that injector and send it a pump shop where it can be "pop" tested. If it passes the "pop" test you"ll need to figure out the problem within that cylinder- valves, rings,gasket, eroded liner;etc. I hope for expence sake it's the injector.
Old Dec 13, 2006 | 10:37 PM
KJLYPW's Avatar
KJLYPW
With 200K on original injectors I would bet that none would pass the pop test. Buy a rebuilt or new set on E-bay from Diesel Care and Performance, get the same Code as you currently are running B, C, D, E, G, or ?. The code is stamped on one of the flats of the injector, change out return lines and o-rings while your at it. The stuff is cheap enough 150-200 dollars depending on if you buy new or rebuilt, so just get er done. IMO
Old Dec 13, 2006 | 10:58 PM
catfish101's Avatar
catfish101
Fuel nozzles and fuel injectors are a wear item. The tips will errode and not atomize fuel correctly. I would definitely replace them. Bad nozzles and injectors are what takes out most cylinders. You are playing with fire when running them along time. I don't disagree that alot of people have gotten alot of miles on nozzles and injectors but I have also made alot of money fixing the ones that didn't. It is not waisted money.
Your "miss" can be from a nozzle that isn't atomizing right. The fuel won't mix with the air right which will cause a stubbling idle. Good luck.
Old Dec 14, 2006 | 08:26 AM
kcw12's Avatar
kcw12
Well im going to get a set from ebay. new delphis i guess. I like buying new instead of remans. Just a personal preference
Old Dec 14, 2006 | 11:12 AM
Kangus's Avatar
Kangus
I installed new glow plugs and a controller, the next step is the injectors and return lines. When I was replacing the glow plugs I noticed three juctions on the return lines that looked like they were weeping, everywhere else is dry. The truck currently starts and idles ok, when I stomp on the throttle I get white smoke.
I changed the fuel filter and filled the new filter with dieselklean, I started the truck and for the first time I could hear the engine, no rod knocks, no sticking lifters!
Let us know how your new injectors workout.
FYI: HarborFreight has a compression gauge #93644 that has the 6.9L adapter for $19.99, if you look at the web they have the old one listed, the one I purchased has twice the number of adapters including a 10-1.00 mm.
84 F350 6.9L 2WD
Old Dec 14, 2006 | 03:00 PM
Tom D's Avatar
Tom D
Injectors
I read in one of the previous posts that injectors and IP from a 1994 DI turbo diesel should be used as a replacement for the 93 IDI. Any one got a comment?
Old Dec 14, 2006 | 09:33 PM
KJLYPW's Avatar
KJLYPW
My 93 non turbo was 5013 pump with code E injectors, The 93.5 - 94 turbo motor used a 50?? (not sure of #) and G codes. More fuel for the turbo application!
Old Dec 14, 2006 | 10:36 PM
Dave Sponaugle's Avatar
Dave Sponaugle
93 and 94 turbo used G injectors
DB2 5069 with the automatic tranny
DB2 5070 with a standard tranny
92 thru 94 non turbo used E injectors
DB2 5028 with an automatic tranny
DB2 5013 with a manual tranny
Old Dec 15, 2006 | 06:37 AM
F350_Hauler's Avatar
F350_Hauler
Shouldn't that say 94 IDI instead of 94 DI? I remember reading that previous post as did Tom and I wondered at that time if a DI turbo motor injector would fit into an IDI motor.
Old Dec 15, 2006 | 08:48 PM
Bigredcrew's Avatar
Bigredcrew
Dave, I have a 93 non-turbo w/manual tranny. It has E injectors and a 5028 IP. I suppose the IP might not be original. What's the difference between the 5028 and 5013? More fuel out of the 5028?
Guy
Old Dec 15, 2006 | 08:55 PM
KJLYPW's Avatar
KJLYPW
Yah Dave, my 93 non turbo with E4OD has a 5013, as was original. Maybe the data base has the two numbers swapped or ???
Old Dec 15, 2006 | 10:33 PM
Dave Sponaugle
I will have to look it up again, my work schedule has made it hard for me to keep up with all the new posts here lately.
I may have transposed the numbers when I was typing that.
The only difference I have noticed is bosses for the tranny VRV or FILP on the automatic.
Time to hit the rack, gotta get up in five hours.
