IRRATIC Tach!!!!!!
Old Dec 12, 2006 | 07:42 PM
zzjonze's Avatar
zzjonze
IRRATIC Tach!!!!!!
I dont mean a lil Irratic like it has been since I got it...I mean Real irratic!!!
When I got it I will set and idle about 700 RPM.I rev it up and it takes a while for it to register, then it cant be readint right.
I got in and took off the other morning and found it ammusing to see it red line at 6 grand but when I steped on gas it went all the way around once maybe twice. LOL!!!
My Truck is a 4.9 engine, 1987 f150 4 speed,4x4
The tach was acting real weird since I go it as I said but I have been busy repairing rust to fix this problem. The time has about come to fix it.
So I need your expertise in troubleshooting my Tach.
Anyone have any ideas?
ZZ
I didn't know the needle would go all the way around.
Old Dec 12, 2006 | 08:15 PM
quicklook2's Avatar
quicklook2
from ford manual:
1. check fuse
if fuse blows find short
2. check for loose wiring connections in engine compartment or at instrument cluster
secure loose connections
3. inspect inst. cluster printed circuit for damage, poor connections or open circuits
if damaged replace instr. cluster.
Old Dec 13, 2006 | 07:05 PM
zzjonze's Avatar
zzjonze
I think I found the cluprit. it was a white wire going to the distributor not making good connection ...
Atleast it is not as IRRATIC as it was.It doesnt go all the way around now.
ZZ
Old Dec 13, 2006 | 08:52 PM
quicklook2's Avatar
quicklook2
hope that was it.
