1978 - 1996 Big Bronco
95 Bronco won't start
Old Dec 12, 2006 | 06:28 PM
bigboylk's Avatar
bigboylk
I pulled the codes and got a 542 code, (fuel pump secondary circuit fault). The engine turns over but will not fire. Is it the fuel pump relay and if it is, which one is it? There are about 5 relays in the large fuse box on the firewall and 4 relays in a rectangular box next to the fuse box. Also, do the relays pull straight out of their holders?
Old Dec 12, 2006 | 07:22 PM
Aciancio's Avatar
Aciancio
check the inerta switch, it is behind the passenger kick plate
Old Dec 12, 2006 | 08:34 PM
quicklook2's Avatar
quicklook2
number 2 relay in engine compartment and fuse 16 20 amp maxi is fuel feed
Old Dec 12, 2006 | 08:52 PM
tom2131968's Avatar
tom2131968
The fuel pump relay is the green one.
