well , there was some question as to wether or not my motor was a ford or a merc.... my heads are! but again confusion about the block. but I do have an answer as to the bore and stroke! 4-1/8 stroke and 3-3/8 bore. and also very spun rod bearing as of last thursday! but I learned my lesson about pushing a old motor to far! she sure got loud and angry with me lol, time for a rebuild .
That block is just about at its max for the Street. Not much left in the Cyl walls for cleanup. Make sure whoever puts her back together has done a big flatmotor before.
I'm not sure yet what is going to happen. may end up going a modern route. I don't really want to but I have a 400 + HP 429 in my 4x4 , thats fresh and emission regs won't let me run it
Sounds like you have a full house flatty! If it is what you say it is worth more than your 429, not to mention its nostalgia value, to me that is a keeper for sure. If you don't want to keep it let me know.
That crank must be a welded up Merc, with that stroke. If it was done poorly, maybe that's why you have a spun bearing. Is this the engine that had like 100 psi compression? With that bore/stroke, it should have had huge compression.
well to answer the full house question first. 78 f100 4x4, 429-c-6 auto, 62 pontiac grand prix 421 superduty-tri power-8 lug magnesium wheels 4 speed, posi. 65 galaxy 500 convertable, 390 auto 49 cj 3-a , 51 f-1, 85 jeep cherokee (AMC) wife's toyota corolla(lol) 48 knucklehead. 65 hallet flatbottom v-drive, 42 kayot 8 sleeper houseboat. lots of DMV fees, high taxes, huge insurance bills and one very annoyed wife! second question , yeah , its not pretty. I am not exactly sure who did the motor but they certainly werent doing me any favors. it had over a hundred psi compression. who ever did it didnt even paint up the block or heads. its certainly been bored and stoked a bit. but not gently.they didnt even replace the cam apparently. If I can talk the wife into it, it may get done right.but she has about had it with my vehicle addiction. a couple may even go on the auction block. she wants to buy bigger house after the first of the year.
I apologize I didnt read your question correctly, I don't understand what a full house flatty is . it ran good till she gave up a ghost. it may get rebuilt but certainly not before the new year.(if its possible to rebuild)
Full house doesn't have a direct translation, but you've got the right idea.
At 3 3/8" it's as big as it'll go - probably. A very few will bore to 3 7/16" but not many will survive it without hitting water.
When you take it apart, check the con rods - it might have 21A rods which were for the earlier flatty. If so, it would allow for off-set grinding of the 4" crank to go to 4 1/8".
You might also find that 1 wide bearing set is used for 2 con rods rather than the modern system of each con rod having it's own bearing.
Anyway, thats 'full-house'. Max bore and max stroke (without spending $$$ for a new stroker crank)
That full house term was what was used in racing flathead motors back in the days. They offset the rod journals and turned them to 1.998, using early rods
(32-42), and full floating bearings. Max bore is considered to be 3/16 over stock which is 3 3/8". This results in a 296CI motor. Hopefully you can rebuild without having to mess with the bore or stroke. I don't know for sure if they make the sleeves for a 3 3/8 bore but somebody probably does.
good luck with it anyway, it would be a real kick to have that motor regardless of what shape it is in.
I have a certified marine mechanic freind who says he has done a few flatties over the years . he says he will help me with it . if its not rebuildable I will try and find a new block.
Tomorrow my mechanic buddy and I are going to completely disassemble my flatty. we are going to inspect everything, plus his father will be up from la tonight apparently be built and raced a few back in his day and according to ,my mechanic is kind of excited about looking at the old girl. with any luck I will still have something to work with
