power lock actuator
Old Dec 11, 2006 | 10:48 PM
jsmith6752's Avatar
jsmith6752
power lock actuator
I have a 92 with power locks. I found that 1 was off the bracket preventing it from coming up. I can't figure out what holds it in place. I found nothing in the bottom of the door. I tried a wire tie but I could not hook it all the way around. Any suggestions?
I also have a leak on the top of the manual transmission. Do I need to remove the floor pan for a closer look or is this something with a common fix. Ok last one. The 6 cylinder has developed a rough idle. It runs great but bucks at low rpms when it first starts off. The truck sat for some time but did'nt have this problem originally........thamks...jim
