Solenoid??
Old Dec 11, 2006 | 09:55 PM
bhodgin's Avatar
bhodgin
Solenoid??
I am having trouble with my 87 302 I get no response when turning the key, truck will not start unless I jump the solenoid, starter is fairley new, new ground, and a new soleniod, I am lost Help!!!!!!!
Old Dec 12, 2006 | 08:41 AM
Franklin2's Avatar
Franklin2
Sounds like a neutral safety switch or the clutch pedal switch if it's a manual tranny. Look on the side of the tranny if it's an automatic, for the neutral safety switch, or on the clutch pedal arm if it's a manual tranny. The wires to look for are red/blue. You should see two of these wires. If you unplug the switch, and make a jumper for these two wires, jump across them and see if it will start.
