Engine trouble
Old Dec 11, 2006 | 05:49 PM
bigredman's Avatar
bigredman
Engine trouble
I need help troubleshooting my engine trouble. The truck starts just fine, and it seems to run alright when the engine is cold, but when it warms up the motor misses during acceleration and while maintaining speeds below 45 MPH. I changed the spark plugs and wires but that didn't fix anything. My truck is an 86 F-150 302 FI V8.
Any advice appriciated, Thanks.
Old Dec 11, 2006 | 08:41 PM
scottie2hottie's Avatar
scottie2hottie
try ignition coil. on my 87 302 efi it would only start if the truck was cold, it would never start when warm. the coils are mounted to the valve cover so they get hot easy. Also possibly control module on distributor.
Old Dec 11, 2006 | 09:42 PM
paden's Avatar
paden
If those don't show anything look at the distributor and timing. You may be getting some slop in the timing system.
It sounds most likely like it is an electrical problem though since heat seems to be a factor.
Old Dec 13, 2006 | 10:50 AM
stancel's Avatar
stancel
Missing
Changed your fuel filter?
Old Dec 13, 2006 | 11:42 AM
Kemicalburns's Avatar
Kemicalburns
PULL CODES, always do this first before replacing anything. otherwise your just chasing ghosts. www.fordfuelinjection.com will show you how using a paper clip and a few mins of your time.
how many miles on the motor, what kinda spark plugs you using. the TFI module mounted on the dizzy will cause issues like this as well. all suggestions above are good to follow for sure.
