tranny upgrade
Old Dec 11, 2006 | 02:50 PM
buckethead5k's Avatar
buckethead5k
tranny upgrade
have A 4 speed, want upgrade to 5 spd! have 302 motor. I know that there are many different versions to choose from, what are my best options, what should I stay away from, just a good all around sturdy tranny that will last!
Old Dec 11, 2006 | 03:23 PM
7DF250's Avatar
7DF250
I think it may be overkill but the ZF or NV4500 would be sweet. I am not sure the T5 would hold up in a truck or the NV3500 I think is used in Dodge Dakotas with V8's so it may be a good and plentiful canidate.
Old Dec 12, 2006 | 10:24 AM
TigerDan's Avatar
TigerDan
Be easy to swap in an M5R2 as found in 1988 to present Ford F150 series trucks and full size Broncos with a 300-6/4.9, 302/5.0, and 351W/5.8. Lighter duty tranny than the ZF but still not a bad one if you replace the 3 rubber plugs on the shift rails with steel soft plugs to stop tranny oil leakage.
