Start up trouble
Old Dec 11, 2006 | 10:27 AM
stroke25's Avatar
stroke25
Start up trouble
I have a 04 6.0L. When it started turning cold it has really struggled on start ups. It turns over several times before starting, once it starts the idle is real ruff, almost like a gas burner missing. Once it has idle for 5 minutes or so it's o.k. I have heard this is sometimes common with the 6.0's, but I hate the fact that my truck sounds this way. The only mods are cold air and turbo-back exhaust. Oh yeah, it also passes a little blue smoke. Does anyone have any ideas?
Old Dec 11, 2006 | 10:38 AM
origcharger's Avatar
origcharger
Have you had your batteries load tested? Not saying it could cause all your symtoms but it is the place to begin.
Old Dec 11, 2006 | 11:13 AM
BowTieHatr's Avatar
BowTieHatr
it sounds like you have one or more injectors sticking. tsb 6-22-3 refers to a reprogram ans should fix your issue. if not a injector or 2 might have to be replaced.
Old Dec 11, 2006 | 12:39 PM
catalinagoose's Avatar
catalinagoose
If it's an early build '04, you should also have the ICP sensor checked out. They fail regularly and can cause similar symptoms.
