trailer wire harnes/utility winch, is the wiring strong enough?
When you run the wire from the battery make sure to put a circuit breaker or fuse in the line. Something like the 100A with the red button #46985:
http://order.waytekwire.com/IMAGES/M...og/219_081.PDF
For the length I would use #4 AWG wire.
Now though, I do want to get to the bottom of why this wire is powered all the time if it's not supposed to be. I could see this wire, somehow, draining my batt down in the future and at the wrong time.
People are always changing something around to suit their own needs.
Take a look at where the TT bat. charge relay should be and see if there is a jumper wire in it's place. That would keep that circuit hot all the time. If there is a jumper, remove it and replace the relay. Also check the fuse and make sure that it's not jumpered or oversized.
Like Dave said above, lots of guys do these mods (right or wrong) to have full time power at the TT plug.
phydeauxman
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
13
06-02-2020 03:49 PM
hasteranger
02-29-2012 05:13 PM
