Cam
Cam
Is this true?
<CENTER>CAUTION!
</CENTER>"Stock intake valve springs go solid (coil bind) at 0.490" valve lift. The stock springs on early non-rotating exhaust valves allow the same lift as the stock intake valve springs, but the springs on the later rotating exhaust valves go solid at just 0.480" valve lift. That is less lift than many popular performance cams provide, even the milder ones like the Edelbrock #2172 (0.484/0.510 gross lift) and the Comp Cams 255DEH (0.469/0.505 gross lift). Using the stock rotating exhaust valve springs and retainers with either of those cams will cause bent push rods. "
<CENTER>CAUTION!
AFAIK it is. Always get the cam manufacturers recommended valve and spring setup.
Look here:
https://www.ford-trucks.com/forums/s...61&postcount=1
Look here:
1978fordxltranger
03-20-2015 11:52 AM
Jayman1976
07-26-2013 06:41 PM
AstroFab
09-08-2011 04:33 PM
cathode
01-24-2011 01:31 PM
