Front Axle Leak
Old Dec 10, 2006 | 09:51 PM
Stlrrig's Avatar
Stlrrig
Front Axle Leak
I have an 03 Excursion 4X4. The front axle is leaking from the passenger side. I noticed when I was changing the oil. The area is wet, but there is no puddle under the truck. I took it to the dealer and they told me that the inner axle seal is leaking and quoted me a price of about $1,000 to repair (including 9 hours labor). This sounds like a lot for an axle seal. I usually do most of the minor repairs to my vehicles, but if it takes the dealer 9 hours to do then it will take me way too long. Does this quote sound right? Is this the type of job a backyard mech can do? Any special tools required? Would it be better to go to a "non-dealer" repair shop to have this done? No mods have been done to the suspension of the X. Thanks in advance for your help.
Stlrrig
03 Excursion Limited 4x4 6.0L PSD
Old Dec 11, 2006 | 08:29 PM
Truck Monkey's Avatar
Truck Monkey
Cool Axle leak
Good luck! I just did mine. Searched and asked questions for three weeks with no reply. Just fixed mine(with some 'Afro' engeneering) The inner seal(2C3Z-3254-AA, $35.79) that's leaking sits on inside of axle tube. To replace it means that you need to pull pumpkin cover and take axle gear set out to get to seals(AS far as putting these gears back you need special tools & gages for correct thrust washer placings). The seals{dust covers} (F81Z-1S175-HCA, $19.92)that is on outside of axle tubes do not have a oil tight seal to axle tube. When you pull hubs apart you also need outer oil seal(F81Z-3254-AA, $31.03)+$10ea for your Ford dealer to fit them to axle,hub o-ring(F81Z-4A322-AA) and one auto hub o-ring kit(4C3Z-1K106-AA). NOW here's my fix. I replaced all above seals AND from Napa got oil seal(16146, $6.99) and installed it between stock 'dust cover' and axle tube. **This seal 16146 is a little too big to fit into axle tube hosing, but with some @!!%*^!! it WILL go in. What this do is when oil leaks past inner oil seal it will just lay in axle tube, instead of leaking to ground, and thus NOT draining fluid from axle, do top-up. You can do a side in a couple of hours with no special tools(other than a 2 5/16" wrench for lower ball joint and circlip pliers). I put synthetic oil in my axle??
2000 X V10 4x4 96k Dana50/229 axle/ 3.73
Old Jan 31, 2009 | 08:56 PM
chrisrummy's Avatar
chrisrummy
what special tools were used to put in the inner axle seal?
Old Feb 1, 2009 | 02:21 PM
vettdvr's Avatar
vettdvr
You are correct in everything you covered. You should also cover you had to really clean the axle to pass through the (new external seal) so as to not damage it. But if you can make the seal fit inside the non machined housing and get the axle through it you might be on to something. Note however that until enough oil leaks into the housing you will still have to top off the diff.
Yes I use synthetic in the diff as it is required.
Old Feb 2, 2009 | 11:59 PM
chrisrummy's Avatar
chrisrummy
just got my inner axle seals reinstalled and everything is looking good thanks for all the help
Old Feb 3, 2009 | 09:49 AM
vettdvr's Avatar
vettdvr
Could you confirm part #'s?
Also any photos or issues?
Thanks and hope I don't need any of the info as I just replaced my wheel bearings and seals.
Old May 10, 2009 | 03:18 PM
soutthpaw's Avatar
soutthpaw
Just for clarification as I have seen this mistake mentioned several times... you DO NOT need any special tools to remove and reinstall the Differential ring gear as far as the backlash or contact pattern. The Bearing shims sit between the Bearings and the Differential. the bearings are pressed on so they won't fall off! However the Dana 60 housing has preloaded bearings so its a tight fit to get in and out. a porta power (guess this would be a special tool) can be used to spread the housing a few thousandths of an inch so u can get the differential and bearings back in after changing the seals...
Just did mine yesterday... replaced all the seals/o-rings plus new front wheel bearing/hubs... took about 6hrs. But having wrenched in a 4x4 specialty shop I know the secrets I used a piece of 5/8 threaded bar an a couple of 2"/50mm sockets to push the inner axle seals into place just tighten the nuts away from each other and it will press the seals into place
Old May 10, 2009 | 09:24 PM
EXv10's Avatar
EXv10
You could probably use a come-along with a fulcrum point to spread the bango for spider cage and ring gear removal and I've put hundreds of seals in with minimal tools. (Hammer and sockets usually.) I don't know how the axles are retained but I usually never had to remove the carrier.
Old Jul 9, 2009 | 01:44 PM
Tx1ton's Avatar
Tx1ton
Any pictures available of the procedure to replace the inner seals for the front axle? I need to do it and appreciate any documentation out there!
Old Jul 9, 2009 | 02:28 PM
EXv10's Avatar
EXv10
You might not get pics because not many people tackling it.
Old Jul 9, 2009 | 02:29 PM
Tx1ton's Avatar
Tx1ton
Any service manual links perhaps?
Old Apr 12, 2010 | 08:34 PM
02EX73's Avatar
02EX73
03 7.3l EB Excursion 165K miles. We were quoted $1200 here in Maine at our dealer. This is not worth my time and the number of bloody knuckles I'll end up with.
Old Apr 12, 2010 | 09:25 PM
EXv10's Avatar
EXv10
Don't forget to give the stealer a tip
mattdoc88
Mar 3, 2015 06:31 PM
Bite N Hold
Dec 25, 2014 07:41 AM
Pilgrim
Jun 2, 2014 11:59 PM
jim4366
Mar 4, 2011 10:59 PM
Rancha9
May 14, 2006 12:09 PM
