low power
Old Dec 10, 2006 | 08:26 PM
griz1974's Avatar
griz1974
Angry low power
i have a 1980 f150 4x4 with a 5.0 and manual lockouts and a auto.
it seems like it does have any power it run fine at idle but when u take off its slow new plugs and carb rebuild
Old Dec 10, 2006 | 09:12 PM
bob1987f's Avatar
bob1987f
cam, heads, 4bbl intake, and 4bbl carb. youll be able to light em up then!
Old Dec 10, 2006 | 09:24 PM
P51D Mustang's Avatar
P51D Mustang
Check the ignition timing. This will help to optomize the stock motor, and costs nothing. Ofton you will have the timing set to the point were it runs fine (smooth as butter), but there's not enough advance to get much power. It should be at least 10* and perhaps as much as 12*, ( set at idle with the vacuum disconected of course) by my experiance.
If you want big time power, then you will need to start replacing parts.
Old Dec 11, 2006 | 10:00 PM
griz1974's Avatar
griz1974
Smile thank u
thank u for the info not looking for a hot rod just getting tired of my truck falling on its face on take off
Old Dec 12, 2006 | 06:13 AM
HemiEater's Avatar
HemiEater
Make sure the exhaust is not clugged.................
Old Dec 12, 2006 | 06:17 AM
ken75ranger's Avatar
ken75ranger
What size tires and gears do you have? It can make a big difference.
65fordman
Jul 17, 2011 07:19 AM
bnoll
2004 - 2008 F150
Jul 29, 2009 12:14 AM
wt4e
Jun 28, 2005 10:02 AM
tite4x4
1978 - 1996 Big Bronco
Dec 8, 2002 03:51 PM
