General Automotive Discussion
Tarus tranny issue?
Old Dec 10, 2006 | 05:28 PM
thefarelaneman's Avatar
thefarelaneman
Tarus tranny issue?
A friend of the wife says her tarus will engage in reverse but does not go forward when put into drive,It was 2 quarts low of fluid and after adding it still no results. Does this mean the tranny is broken, Has 150k on it?
Old Dec 10, 2006 | 09:00 PM
7700Rob's Avatar
7700Rob
What year is it, there were a few different trannys used. Not that it really matters I guess, it doesn't sound good. A good flush would be a reasonable rescue effort at this point. Let us know what happens.
Old Dec 11, 2006 | 07:31 AM
Casey's Avatar
Casey
Will it move with the shifter in 1? I just fixed a Taurus that did this, it wouldn't go in D, but it would in 1. The forward clutch seals had cracked and failed. The trans has a higher pressure in 1 than in D, so it could overcome the bad seals.
Old Dec 14, 2006 | 04:50 PM
thefarelaneman
Its working now after a can of tranny conditioner and it cooled off. Seems the driver let the engine overheat and Im thinking that this also caused the tranny to overheat which caused it to slip.
Old Dec 15, 2006 | 09:13 AM
Casey's Avatar
Casey
The conditioner probably softened the seals so that they are working again, for a little while. Start putting together the $$$ for a rebuild, it's just out there a little ways.
