carbs vs. fuel injection
Old Dec 11, 2006 | 06:17 PM
scottie2hottie's Avatar
scottie2hottie
Probably the two biggest reason are emissions and fuel economy. Those happen to be two things I don't really give a rat's a$$ when I want to gain power. Cost economy for power comes via a carburetor, end of story. He did say he was wanting more power. Just my $.02 you can take it or leave it, but I'm stickin to my story. Don't get me wrong, fuel injection IS a beautiful thing, I use it everyday. BUT, when i want to tinker with power I go to my old carb trucks, and as far as I can see I always will . And yes there is definitely a reason factorys got rid of it, but there is also a reason that a HUGE majority of motorsports still use carburetors.....
Old Dec 11, 2006 | 08:04 PM
TUFFY's Avatar
TUFFY
I also will vote for going carb. I also drive a fuel injection car every day and love it. I took all the fuel injection suff of the 86 motor I put in my truck for 1 it was easer with it being a 1980 and 2 Imo the carb set up is easer to work with.Jmo.
Old Dec 11, 2006 | 09:28 PM
darrin1999's Avatar
darrin1999
on the mileage issue- you really dont get better mileage with efi than a carb... just look at the 460 for an example... in efi form youd get 10-12 mpg... in carb form 8-15... it all depends on the tune... if you tune a carb system for mileage you can get better mileage than the efi, if you tune for power you can get better power from the carb... efi is just the best average they could find between mileage and power, and still meet emissions
Old Dec 11, 2006 | 09:36 PM
buckethead5k's Avatar
buckethead5k
hey I say go with the carb and sell me you efi system for my 72 f100, HEHEHE
Old Dec 12, 2006 | 12:58 AM
77traded's Avatar
77traded
As far as the post about having to replace the fuel pump twice and three injectors in an 86 car, thats nothing considering the thing is 20 years old. How many carbs would you have gone through in that time or mechanical fuel pumps? So I think complaining about those few items is ridiculous! Also if you know what you are doing with fuel injection and have the tools, time, money to do so fuel injection can net more power. Unfortunately efi is still newer in vehicles, been in mass production 20+ years now, unlike carbs which have been around since the first cars came out. Just my .02
Old Dec 12, 2006 | 02:24 AM
darrin1999's Avatar
darrin1999
those fuel pumps and injectors i had to replace all over the course of 2 years and about 20,000 miles, and the car only had 130,000 miles on it when i gave up on it. my grandmother gave it to me because she said i needed a reliable car... so much for reliability... my 1969 mercury monterey was a way more reliable car- and it got better mileage and had more power with a 390 than the grand marquis with a multiport 302
Old Dec 12, 2006 | 04:47 AM
scottie2hottie
I have to disagree a little here. I have NEVER seen a carb'd 460 TRUCK get too much better than 10 mpgs, but have seen EFI 460s 2wd 5spd go as much as 14-15 hwy. I have run across quite a few 460s in my day and at one point had 3 460 carb'd trucks, all 2wd, and not one broke 11 mpgs EVER. EFI has a better way of monitoring the system, so it can achieve better mpgs and meet emissions, while still giving enough power.
I have the intake for a 302 with all injectors, worked good in the truck early this summer, all you'd need is wiring harness and distributor(which I could possibly get both off an 88 bronco) pm if interested.
Old Dec 12, 2006 | 04:53 AM
scottie2hottie
I will have to disagree here, too. Both carbs and mech. fuel pumps stay very operative if you regularly keep the vehicle running, it's only when it sits that the fuel pump rubber rots, or the carb gumms up. My friends dad has a 69 Camaro he bought new and has never rebuilt the carb. He has replaced the fuel pump, but the car sits 7 months a year. IMHO, the EFI is the opposite, with all the emissions BS on the EFI the more you drive the more exhaust you pump back through your vehicle, and the gummier the inside gets. many carb'd(all of mine thanks to some sawzall mods on emissions) don't run exhaust back through the engine, therefore saving it a little. I guess CA, PA, and NJ, and maybe a few others, still have to have that stuff on late model carb'd vehicles though.
Old Dec 12, 2006 | 03:45 PM
ford_guy_08's Avatar
ford_guy_08
no i wasn't goin to go stock. i pretty much think this is all on people's opinions. ya'll all talk about how efi is good on gas. but i promiss you with the older fuel injections they dranked the gas. my grandpa had a 92 302 with efi and it got 13-14 and my 86 302 with efi gets about 11- 12. i don't think ford really figured out efi till the later years. idk seems to me that a 302 should be better on gas when its not that big of a motor. and its not like there is anything wore out on my my trucks motor, because it only has 41000 miles on it,and i've had the injectors cleaned, new plugs, new plug wires, all that kinda stuff. and as afsocmech said," Take it for what it's worth, there's a reason the factories got rid of carbs." i think the reason that the factories got rid of carbs was for more money, and to complicate things. there is more stuff to go wrong on efi and it cost more to get it fixed. same reason all the new trucks run off computers, to make them harder for the average person to work on when somethin goes wrong.
Old Dec 13, 2006 | 12:33 AM
darrin1999's Avatar
darrin1999
nah they did it for emissions, and one big reason your truck gets crappy mileage is your engine just isnt big enough- yes i know it may be counter-intuitive, but consider your engine's workload... lugging around a 5000+lb body takes torque, something a 302 really doesnt have much of. a 300 i-6 has alot more torque and gets about 3 points better mileage a 351w has alot more torque, and would get about the same mileage if not a point better, once you go to a 460 thats more engine than your truck needs, so it doesnt have to work as hard... and you still get 11-12 mpg properly tuned
Old Dec 14, 2006 | 12:40 PM
dumdum9599's Avatar
dumdum9599
i agree with darin1999 my 84 had a 302 in it and was too hard on gas so i switched to 351m and it is better. the motor does not have to work as hard.
Old Dec 14, 2006 | 03:39 PM
Hoganlex's Avatar
Hoganlex
EFI all the way... fuel mileage, better powerband due to superior fuel atomization
Old Dec 14, 2006 | 03:42 PM
  #28
Hoganlex's Avatar
Hoganlex
actually, most motorsports that aren't regulated to death (F1, GT) don't use carbs. Nascar still runs carbs because of the regulations that say all the cars have to be the same, and its too hard to regulate that in a vehicle that has a computer and takes 20 seconds to remap.
Old Dec 18, 2006 | 03:53 PM
  #29
Arnold Kenyon's Avatar
Arnold Kenyon
I had a 1985 1/2 that was fuel injected with a 302 auto overdrive. It was a long bed regular cab. That thing ran circles around every 351HO I ever lined up against. The mileage was better than any pickup I have owned before or since. On the highway it could get in the low 20's. We traded it off at 181K and it still ran well. I sure miss that old truck.
Old Dec 18, 2006 | 04:46 PM
  #30
brianvabeach's Avatar
brianvabeach
I vote for carb.
