Coolant Flush
Old Dec 10, 2006 | 03:05 PM
Olddog66's Avatar
Olddog66
Coolant Flush
The manual I purchased for my truck seems to go overboard on the coolant flush process and I wanted some opinions. It tells me to open the block train plugs on the underside of the engine. Is that really needed?
Old Dec 10, 2006 | 03:19 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
It's up to you really. The block will retain nearly two gallons of fluid after you've drained everything else you can drain. So you either need to install a flush "T" in the heater hose or pull the block drains to make sure you get all the old stuff out.
