Fabtech Lift Kit
Old Dec 10, 2006 | 11:01 AM
i eat hybrids's Avatar
i eat hybrids
Fabtech Lift Kit
I was wondering were the best and cheapest place price wise to buy a fabtech four inch lift kit for a 2wd Ford Excursion. Also how does this kit ride on an Excursion because the ride quality is really bad right now and it just sits way to low to the ground because its 2wd.
Old Dec 10, 2006 | 05:41 PM
ReAX's Avatar
ReAX
It really depends. If you go with the coilover kits it can really change the way it rides. If you reuse the stock springs, the ride should remain the same.
If you don't go with the coilovers, try a set of bilstiens. They should calm the ride down.
Old Dec 10, 2006 | 06:42 PM
i eat hybrids
Reax, its the basic kit that comes with shocks, the coils, the blocks and i think the leafs
Old Dec 10, 2006 | 06:53 PM
ReAX's Avatar
ReAX
Unless you have they 05-current coil spring front end, that would mean you going with the dirt logic coil over kit. It will make a major difference in ride.
Try your local driver FX stores, shipping can get expensive on those kits. Stores that use inhouse trucks get cheap deliverly.
Old Dec 10, 2006 | 09:26 PM
i eat hybrids
What are driver FX stores? How much does shipping usaually cost for these kits?
Old Dec 10, 2006 | 09:48 PM
ReAX's Avatar
ReAX
When I order anything through keystone (big time distributor) shipping is $5.50 reguardless of size/weight. Driver FX is the advertising side.
http://www.partsxdirect.com/retailers.aspx
Some kits must be shipped by truck freight because of size limits, some can be shipped Fedex. Truck freight is immedately $100. I haven't shipped Fedex in a while, but I would estimate $140.
