bad vibration
Old Dec 9, 2006 | 10:34 PM
tunruh's Avatar
tunruh
bad vibration
'95, E350, auto.
I've recently developed a vibration which gets worse as high speeds. It's not related to engine rpm, or tires, so I'm left with transmission tail, driveshaft, differential, axels.
I've been underneath and u-joints are tight. There is about 3/8" play in the differential...normal for 200K. There is also play in the tail piece, and it's noisy. That doesn't seem normal, but it's a spline and shaft, so what could have 'slop'?
I put the rear end up on stands and started the van, put it in gear and watch the driveshaft. Front end is perfect, back end seems to be slightly 'off center'. This is a new vibration and I haven't been in an accident or bottomed out the van. However, it did get shifted from drive to reverse a high rpms, but I was at a standstill. Is it possible to 'torque' a driveshaft? or did I damage something in the tail piece?
To make this more confusing, the vibration goes away when I let up on the gas, coast, regardless of speed. That seems to eliminate the driveshaft and tires.
__________________
Old Dec 13, 2006 | 06:00 PM
bradb2230's Avatar
bradb2230
I wonder if it is the engine mounts?
Old Dec 14, 2006 | 10:35 AM
gustang818's Avatar
gustang818
There is a bushing inside the tailshaft that the yoke slides into. I never had one wear out but it's possible.
I don't think you would "torque" your driveshaft. I think your rear u-joint might be bad. I had the same symptoms in an '89 Ranger with high miles and a new rear u-joint fixed it. Sometimes it's hard to tell with the driveshaft in just by twisting it that the u-joints are bad.
Old Dec 30, 2006 | 09:22 AM
FordF350Baby's Avatar
FordF350Baby
I had the same problem, it was the yoke.
Old Dec 30, 2006 | 11:00 AM
bronco521's Avatar
bronco521
sometimes i've had u-joints seize up on one of the caps,it "felt" tight but was junk.may want to pull the shaft out and check.
