Transmission
Old Dec 9, 2006 | 08:03 PM
357fhp's Avatar
357fhp
Question Transmission
Hi All:
Can somebody tell me where the test plug is on the transmission that you remove to put the temp sender in?
I've had the guages in for a month now its time to hook it up. The directions said to drill and braze or weld the fitting in and i'd rather not do that if I can help it.
Thank you .
357fhp
Old Dec 9, 2006 | 08:12 PM
Uzumati's Avatar
Uzumati
I dont have a pic but from the driverside if you look just in front of where the Harness connects (about half way down the tranny) there is a small plug just above the pan lip. If noone else post a pic I'll get one tommorrow.
Old Dec 9, 2006 | 08:27 PM
Orezona's Avatar
Orezona
This is from DieselManor install sheets http://www.dieselmanor.com/diy/PSD3-gauge/image16.htm
It's between the 1st and 2nd pan bolt.
Hope this helps
Old Dec 9, 2006 | 10:22 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
