Sponsored by: Real Truck
Sway Bar Link Torque Values?
Old Dec 9, 2006 | 05:25 PM
Jim59's Avatar
Jim59
2002 F250 SD 4X4 5.4 Auto CC LWB
Intalled two new links on the front anti-sway arm today. Does anyone have the correct torque settings ..... for the bottom bolt that attaches the link to the sway bar, and for the top bolt that attaches the link to the frame mounting bracket?
A friend told me that his Haynes manual stated 85 ft lbs for both. It sure took more muscle to break the bolts free when I removed them.
I have to break down and buy official manuals for this truck. The last time I bought the manual set for a truck was for my '84 F250HD ....... it cost $65 total for all the Ford shop manuals for the truck (engine, electrical, emissions, diagnosis, big fat main one, etc). Now how many hundreds of dollars are they? Dang.
Thanks
Jim
Old Dec 10, 2006 | 05:30 PM
ReAX's Avatar
ReAX
Just go by the bolt size torque guide.
http://www.sizes.com/tools/bolts_SAEtork.htm
Old Dec 10, 2006 | 05:47 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
The stabilizer bar-to-link nut is 80 ft-lbs, and the link-to-frame nut is 80 ft-lbs as well.
Old Dec 11, 2006 | 03:12 PM
kanertop's Avatar
kanertop
jim59, did this fix cure the initial problem, which I assume is a front end thumping noise?
Old Dec 12, 2006 | 09:54 AM
Jim59's Avatar
Jim59
kanertop ..... nope, it did not.
yes, it is a thumping noise .... on my truck it is on the right side, you can feel it a bit under the front passenger's feet, it is intermittant. I often hear it going over bumps, hard turns ..... but, sometimes not. It also seems that I don't hear it on cold mornings until I have been driving for a while.
It seems that replacing the links solved the problem for many here, but not in my case, after replacing both links with oem parts on my stock truck.
I replaced both ball joints (using the great write up on this forum) on the right side a short while ago, thinking that was the problem.
Next, I'm going to replace the bushings where the sway bar mounts to the axle.
The lower ball joint was loose before I replaced it .... other than that, I can not find and looseness in my front suspension when i crawl under there.
Any ideas?
Jim
Old Dec 13, 2006 | 01:03 AM
03V10SonicBlue250's Avatar
03V10SonicBlue250
if you already replaced the links and still have noise try this: disconnect links from sway bar. strap the links up out of the way from banging against anything. do the same with the sway bar just to keep it out of the way. now take truck for a road test over the type terrain where you normally duplicate the noise. *** BE CAUTIOUS: on sharp turns as the truck will roll alot in the front end with bar disconnected*** if the noise is gone then i would say check those sway bar bushings. if the noise is still present, its time to forget the sway bar and look elsewhere.
spring pads on these trucks break also causing a clunking noise on rebound.
another area often overlooked is shock absorbers. if they are over-extended the internal stops can be damaged causing the same type noise. (often imitates a broken sway bar link)
--Chris
