Sponsored by: Real Truck
tranny cooling
Old Dec 9, 2006 | 05:08 PM
Spectre 023's Avatar
Spectre 023
tranny cooling
do the 5.4 or 6.8 superduties have any form of transmission cooling from the factory?
i was looking at mine and i see the radiator, with another large cooler in front of that..presumably for the air conditioning?
but theres also a third cooler, a rather small one, mounted at an angle underneath the second large cooler infront of the radiator.
is this maybe a tranny cooler? if not, does anyone know what it is?
i want to put a transmission cooler on the truck if it doesnt already have one, but i dont want to have 5+ coolers hanging around if i dont need them there.
Old Dec 9, 2006 | 06:49 PM
6L PWR's Avatar
6L PWR
I would assume they do just like my diesel. It's actually in the radiator on mine.
Yes, A/C condenser.
Power steering fluid cooler.
Old Dec 9, 2006 | 08:15 PM
thedaddycat's Avatar
thedaddycat
If you want to run cooler tranny fluid, you could also install a Mag-Hytec or other aftermarket tranny pan. I have the M-H pan here but have not installed it yet. When I do the install I will be changing the internal and in-line filters along with doing a flush.
Refer to this post by FTE member Bear Hunter on the Truck Blog site for the "How To" on flushing the 5R110 Torqueshift tranny.
http://www.truckblog.com/story-582-h...t_transmission
Some things about the M-H pan is that I liked and why I went with them instead of another maker:
Largest extra capacity that I saw listed in the specs at 8.3 pints of extra fluid.
Port for a tranny temp sensor.
Cooling fins cast into the pan, both internal and external fins means better cooling.
O-ring seal.
Magnetic drain plug.
Serialized part. Mine is #974 for the 5R110 tranny and I've registered it with them.
According to the literature that came with the pan, lowering fluid temp from 195F to 175F doubles fluid life from 50K to 100K miles. Cooler fluid temps is something that both the fins and the extra capacity will help achieve.
Old Dec 9, 2006 | 10:56 PM
Spectre 023
ok, so im going to put a transmission cooler in.
where is the best install place?
to the back of the ac condenser or to the front of the radiator?
and exactly what hoses to i need to run?
Old Dec 9, 2006 | 11:17 PM
6L PWR's Avatar
6L PWR
From other threads I've read on here, there's no need to add an aftermarket tranny cooler. The 2003 and up have a very good one as is. If you really think you need it cooler, try changing to a Mag tranny pan as thedaddycat suggested. With an aftermarket cooler you have more of a chance of fluid leaks. I'll try to find some of the other threads that discuss this since you're not able to search it.
EDIT: I just saw in your profile that you're in a 7.3L. Not the same cooler I have. I'm searching for past posts that might help you out.
Old Dec 9, 2006 | 11:34 PM
Spectre 023
wait a second...
its a 5.4L and its a 2001.
does that change anything?
im on a tight budget and im trying to do anything i can to extend the life of the truck.
i really appreciate any help
Old Dec 9, 2006 | 11:37 PM
6L PWR's Avatar
6L PWR
https://www.ford-trucks.com/forums/5...mission+Cooler
There's one for some good reading.
Redo-EDIT: I just saw in your profile that you're in a (DOH) yeah, 5.4L. Brain Fart. Can't search, think and type at the same time! Not the same cooler I have. I'm searching for past posts that might help you out.
The above post will still apply for yours.
Old Dec 9, 2006 | 11:52 PM
Spectre 023
thanks a million man, i really appreciate it.
the extra tranny cooling has always looked like a good idea to me, and i figured id give myself a little insurance with a cooler now that i have the cash for it, but not if its going to be redundant in teh future
Old Dec 10, 2006 | 12:03 AM
6L PWR's Avatar
6L PWR
And another thread:
https://www.ford-trucks.com/forums/4...mission+Cooler
Old Dec 10, 2006 | 10:53 AM
campin' nut's Avatar
campin' nut
The small cooler on the bottom's not a transmission cooler. Why would you need a power steering cooler? It never hurts to know too much.
Old Dec 10, 2006 | 06:15 PM
6L PWR's Avatar
6L PWR
I don't know. I only know that's what it is because I traced the lines to the power steering pump. I never make too many turns on the drag strip anyway. ROFLMAO
Old Dec 10, 2006 | 10:40 PM
Spectre 023
well....with the 35's that i run and on this big a truck im glad it at least came with a power steering cooler
they might not have hit the crucial points at the factory, but at least we have that little extra, lol
Old Dec 11, 2006 | 05:46 PM
Spectre 023
does anyone know which line is the out line adn which is the in line from the radiator?
Old Dec 11, 2006 | 09:25 PM
6L PWR's Avatar
6L PWR
My buddy pointed out to me today that the power steering pump powers the Hydrobooster on the brakes. That's why it has the cooler. Hard to stop this beast without the Hydroboost.
Old Dec 12, 2006 | 08:03 AM
Casey's Avatar
Casey
The power steering system can make a lot of heat even if you are not turning. The pump is making pressure all the time, and that shears the fluid. Shearing fluid makes a lot of heat, so it needs a cooler. Even trucks that don't have hydraboost have power steering coolers.
