tach problem
Old Dec 8, 2006 | 08:00 PM
jobrist's Avatar
jobrist
Wink tach problem
also my tach reads 0 at idle but when i give a little pedel it jumps up to 10 and is fine the rest of the way up. sensor problem or bad tach or something?
Old Dec 8, 2006 | 10:38 PM
dieselbogging's Avatar
dieselbogging
Tach sensor is my first guess.
Old Dec 9, 2006 | 08:22 PM
PLC7.3's Avatar
PLC7.3
The dead tach sender should/would send the automatic trans into a "failure management mode" (limp mode) with harsh engagements and firm shift feel, and an abnormal shift schedule. It has no effect on a manual trans only the Tach readings.
Replace the tach sender on the oil fill housing a big 1" nut with 2 wires. Ford only part Engine RPM sensor E5TZ-17B384-A about $50. You can remove and clean it but usually changed later too. You can test it too, hold it in the air away from ferrous metal, using an ohm meter lead on each wire you need DC resistance between 2000-3000 ohms.
Please put up a signature with truck particulars.......
