Sponsored by: Auxito
Broken Wheel Studs
Old Dec 8, 2006 | 06:48 PM
crazyjake123's Avatar
crazyjake123
Cool Broken Wheel Studs
I have a 97 F-150 with a 6inch sus. lift and 3in body lift. I have had on a couple occasions now all five wheel studs break off while driving, it starts with wobbling and then bam, they are broke, and it isnt a hard fix but just a pain in the *** and I don't understand why this is happening, I go 4Xing in it, and try to get allignments done so often, one person told me the camber is off. Please help... Thanks
Old Dec 8, 2006 | 07:09 PM
thehawk789's Avatar
thehawk789
bad wheel bearing? or yeah it could be the lift kit, if the problem wasnt there before... id think of what is different now.
Old Dec 9, 2006 | 12:37 PM
preppypyro's Avatar
preppypyro
Thats strange for sure. You have the right bolt pattern and studs on your rims right?
Old Dec 9, 2006 | 02:41 PM
galaxie641's Avatar
galaxie641
Do you have the '99+ 14mm stud hole rims? If they got loose at all those could contribute, since your studs are 12mm. Every time I have heard of this happening it has been with a truck with bigger tires and a lift, could just be coincidence.
Old Dec 9, 2006 | 04:15 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
Are they torqued to spec... that would be the first thing i would check.. to loose and they begin to wobble... to tight and they weaken the studys severly...
