electrical frustrations
Old Dec 8, 2006 | 05:15 PM
scottfreeman's Avatar
scottfreeman
Cool electrical frustrations
I have a '69 and am being haunted by a short or a bad ground. When going done the road and hitting bumps the stereo will cut out. It does the same thing when I put it in reverse, and when I turn on the wipers or headlights it loses all power. I have the dash all torn apart and haven't been able to find anything yet. Please reply soon if you have any suggestions this is my daily driver and the only driver I have. My '66 Falcon has the engine out of it, so I am down to one vehicle. I hate electrical, I think it is black magic.
Old Dec 8, 2006 | 05:36 PM
Hypoid's Avatar
Hypoid
Sounds like a ground issue, run a wire from the radio ground or case to the truck's metal chassis. Use good quality fasteners and terminations. If you are using a wire in the loom for a ground, unhook it. It is probably a switched (lights maybe?) power wire.
Ford radios grounded through the case. I can't count the times someone (including me) used the instrument lighting wire for a ground. Dark with a tracer, hmmmmm.
Old Dec 8, 2006 | 05:38 PM
scottfreeman
I have the stereo grounded to the dash, It worked fine for 6 yrs. It just started this a week ago.
Old Dec 8, 2006 | 05:40 PM
jowilker's Avatar
jowilker
Don't laugh, but take the dimmer switch up off the floor and clean the underside real good. Hey if it doesn't help you only lost about 15 minutes, and no money.
John
Old Dec 8, 2006 | 05:42 PM
scottfreeman
Eh? I'll give it a shot, seems strange though.
Old Dec 8, 2006 | 05:51 PM
scottfreeman
Seems to have done the trick, strange. See, I told you. Its black magic.
Old Dec 8, 2006 | 05:54 PM
scottfreeman
Thanks for the speedy reply. Now I just have to come up with a new turnsignal switch. the wire broke right by the lil tab that connects it to the cam. I will try to sodder it back together, it appears that it is wired in. Any suggestions here?
