Fuel gelling
Old Dec 8, 2006 | 02:15 PM
timslawn09's Avatar
timslawn09
Unhappy Fuel gelling
I have a 91 f350 7.3 diesel that has been a pretty good work truck! Recently I have nothing but probs!! after all those were fixed, i went out thismornin and cranked it up like normal. It ran for about 4 mins then shut down and wont crank at all. it'll turn over but no crank. the temp here in va got down to about 18 last nite. does this sound like gelling or water? and what is the best way to bleed the lines by myself, if they need it? Im not a diesel machinac but seem to be becomeing one!!
Old Dec 8, 2006 | 03:35 PM
gumboluvr's Avatar
gumboluvr
Have you been using any additives? It sounds like it gelled on ya. It has been cold enough for water to freeze prior to last night. I would get some diesel Kleen and pour in the tanks, and try to get some heat under the truck by the gas tanks and a hair dryer on the the fuel filter. Aren't the temps supposed to get around 40 tomorrow?? That'll help ya out. Good luck
