Aerostar Ford Aerostar
Can Someone Help My Heaater problems?
Old Dec 8, 2006 | 07:03 AM
lkonig's Avatar
lkonig
I haave the same problem on both my 93 Aerostar and my 99 F150.The heat only comes through the defroster.I have no floor or mix heat.Does anyone know the cause and how to fix it quick.It is in the teens today and should be there againg tommorrow.Thanks for any help in advance
Old Dec 8, 2006 | 09:34 AM
Bear River's Avatar
Bear River
Former ******
Repair and replace your vacuum hoses. The blender do is controled by vacuum, and if there is a broken or disconnected vacuum hose leading to it, it will get stuck in defrost mode. The vacuum motor is above the engine near the blower motor . It has a small diameter vacuum line running to it (unless that part broke. I would trace the lines all the way back to the nearest tee and eplace the entire section. These hoses get brittle after sitting under the hood for over ten years exposed to the intense heat.
Old Dec 8, 2006 | 05:22 PM
B-Aerostar's Avatar
B-Aerostar
Check the vacuum line right behind the glove box it gets knocked loose easily. Its orange and white I think
Old Dec 10, 2006 | 03:21 PM
xxpwillyxx's Avatar
xxpwillyxx
f-150s have some electric actuators instead of vacuum, and it isn't always the actuator in the f150's that goes bad, i did one where the door was broke and required removal of the entire dash assembly to replace it.
Towster
Oct 25, 2016 07:57 AM
Brian Thompson
Oct 3, 2015 08:45 PM
theeconomist
Escape & Escape Hybrid
Nov 11, 2011 10:59 PM
PastorPaul
17
Apr 28, 2011 08:31 AM
emilearl
1997 - 2003 F150
May 16, 2003 08:57 AM
