Open differential question
Old Dec 7, 2006 | 07:17 PM
RangerPilot's Avatar
RangerPilot
Question.
When you burn out in an open differential, is it always a certain wheel that burns out. Every time I burn out in place, my passenger side unsticks. Is there a reason it does it with the passenger side and not the driver's side?
Thanks, just trying to build up a little knowledge.
Old Dec 7, 2006 | 07:30 PM
andym's Avatar
andym
It's because of the direction the driveshaft spins. It has a rotational effect on the rear axle, and it wants to push one wheel down and lift the other off the ground.
Old Dec 7, 2006 | 07:33 PM
WarWagon's Avatar
WarWagon
Torque unloads the passenger side tire allowing it to loose traction. Once it looses traction, most of the power goes to that side. Even with a posi or locker, there is torque unloading and in high HP situations, certain measures need to be taken so the car launches straight.
Old Dec 7, 2006 | 07:59 PM
pronstar's Avatar
pronstar
You could put just the driver's side tire on a slick surface and it will spin...but the above explanations are correct when the rears have equal traction.
Old Dec 7, 2006 | 09:06 PM
RangerPilot
Oh ok...I always just wondered if there was a certain reason that one wheel unstuck normally. Thank you all.
