Sponsored by: Real Truck
Which amplifier
Old Dec 7, 2006 | 02:46 PM
fei1's Avatar
fei1
Question Which amplifier
Hey guys I am in the process of gathering my stuff for my stereo install. I am going wiht the Pioneer AVIC-N3, 4-60watt Infinity 6x8 speakers in the doors (supercab) and I want an amplifier to complement these speakers. I have been doing my homework and I have decided to get a 4-channel amp but I am indecisive on which brand to go with. I am looking for the best value for my money but I don't a piece of junk in my truck. Some of the brands I have considered are MTX and Kicker. I personally am new to this end of the audio world so any help would be appreciated. I also have not yet decided where I want to mount the amp but I am debating with: under the rear seat, under the center seat(front), or between the back seat cushion and the cab of the truck.
Old Dec 7, 2006 | 03:30 PM
TN_Jeeper's Avatar
TN_Jeeper
You have a number of options and both the brands you mentioned above are quality amps. Asking that type of question about stereo equipment is akin to asking which lift or what tires. Everyone is going ot have an opinion based on their experience or worse based on a friend of a friend etc. I have had good experiences with both brands, as well as sold them both in a past life (previous job in college), there are certainly better amps but more cost effective probably not for the set up you are looking at.
One thing to consider. I would recommend running the new speakers off of just the Pioneer Deck and see what you think, it will be a tremendous upgrade over the stock stereo. Then with the money you saved look at adding a sub woofer and mono/dual channel amp. It is very easy later to add a 4 channel to the existing speakers if you decide you need more.
Old Dec 7, 2006 | 03:38 PM
fei1's Avatar
fei1
I definately will try the new headunit and the speakers first. I was told that my speakers will be under-powered with just the headunit. Like I said before I don't know too much about audio but I would like to get the best sound quality with out distorting the speakers and potentially ruining them.
Old Dec 7, 2006 | 04:11 PM
akford351's Avatar
akford351
A 4-channel amp is a good idea... I would just power the front two speakers with the amp and bridge the rear channels for subwoofer duty. I'm not much of a fan of rear-fill... music is recorded in stereo, so I would run the rear speakers off the HU.
http://www.cardomain.com/item/ECLEA4000
Eclipse is high quality and is most likely underrated...
http://www.cardomain.com/item/JBLGTO754II
JBL is also very good quality and will put out rated power...
Old Dec 7, 2006 | 04:19 PM
biz4two's Avatar
biz4two
Arrow
You did not say which Infinity speakers (model number) you are going to run.
However, the head unit has:
Details:
DVD/CD navigation receiver with built-in amplifier (22 watts RMS/50 peak x 4 channels)
Which might be enough, but a good amp is always a nice touch to the system. Might look at this one...Infinity Reference 7451a 4-channel amp.
Good luck...
biz
Old Dec 7, 2006 | 05:28 PM
fei1's Avatar
fei1
The speakers are Infinity Reference 6812cf 6 x 8. Here is a link http://www.crutchfield.com/S-PihvxYP...x8&i=1086812CF
Old Dec 7, 2006 | 06:00 PM
jake00's Avatar
jake00
both mtx and kicker make great stuff for the money.
I'm partial to eclipse
Old Dec 7, 2006 | 06:23 PM
Percys Armory's Avatar
Percys Armory
on a budget this is the best way to go.
Old Dec 7, 2006 | 06:36 PM
92f150I6's Avatar
92f150I6
I am currently using a crossfire amp to run my subwoofer (crystal comp 12)and could not be any more pleased. Seems to be very clean, and I have had it for 5 years, beat the snot out of it. It outlasted my JL Audio 12W3. www.crossfirecaraudio.com
I have also been happy with my Hifonics amp in my car, as it is 8 years old, and still works great.
Old Dec 7, 2006 | 07:46 PM
Percys Armory
Im happy with my Diamond Audio amps
Old Dec 7, 2006 | 07:49 PM
akford351's Avatar
akford351
I've used older MTX, Power Acoustik, Profile, and JBL... MTX & JBL have been very good. Power Acoustik is cheap power (sub duty) and the Profile's are very decent for the money.
Old Dec 7, 2006 | 08:03 PM
joeycyph56's Avatar
joeycyph56
I was under the impression that most replacement speakers really need an amp to maximize thier potential.In my last truck i had rockford 5x7 and i kept blowin them.Then the dealer i was gettin them from told me that the new aftermarket hu wasnt strong enough for them.They needed an amp.although i have seen the expensive infinity in a non pre amp stereo setup and they sounded good.I think i may look infinty next year . good luck man though with your setup.
Old Dec 7, 2006 | 08:51 PM
Percys Armory
underpowered=distortion=blown speaker
Old Dec 7, 2006 | 09:26 PM
fei1's Avatar
fei1
Thanks for all of help guys. I have another question. With all of the electronics going into my truck will the factory batteries have enough juice to power this stuff wil out killing my cranking power? I have 2 batteries because its a diesel but it does draw a large amount of cranking amps to get the beast going. What is your opinions?
Old Dec 7, 2006 | 09:34 PM
04F-250 stroked's Avatar
04F-250 stroked
I wouldn't go with either. Look into a percision power AKA PPI, I've used the same amp and subs (3 JL audio w-6 sub's bridged down to 1 channel)in my last 3 trucks running and still shakes the fillings out your mouth! As far as door speakers go, try seperates. I use MB Quarts in all 4 door also with a seperate four channel PPI , NO DISTORTION what so ever. A little more pricey but will last you a lifetime.
