Early 99 Wastegate
Old Dec 7, 2006 | 01:14 PM
hansont's Avatar
hansont
Early 99 Wastegate
Anybody recall who has these early 99 big head wastegates? I've seen them somehwere, but can't find them now.
Old Dec 7, 2006 | 01:57 PM
Calli's Avatar
Calli
Banks has the Big Head. Carroll
Old Dec 7, 2006 | 04:49 PM
hansont's Avatar
hansont
I found what I was looking for. Thanks.. The reason I asked was after 2 new injectors I noticed now that my turbo doesn't have the pressure it did. I just installed gauges and noticed only 3 PSI of pressure at 70 MPH and 2000 RPM. The max pressure I've seen is 9 PSI. I've got an early 99 with an auto tranny with 223k miles on the beast. I thought the pressure was going to be in the 12-15 PSI. With a healthy motor now could I be leaking by the wastegate?
Old Dec 9, 2006 | 07:07 AM
tommyl's Avatar
tommyl
high PSI equals high fuel consumption!
Old Dec 9, 2006 | 08:29 AM
IDPisan's Avatar
IDPisan
Your boost gauge is going to be the most boring gauge to watch. At 2000 rpm's with the cruise control set my boost reads about 3 lbs. You will see that needle really move when you put your foot into it and the turbo spools up. More boost means more power which equals higher fuel consumption, fun to hear that turbo though!! If you are not generating boost numbers at least in the teens when you are getting on it then you may have an issue.
Jeff
Early 99, F350 CC, 6spd. dually. 6637, staight piped, gauges pyro,boost,water temp, Dp Tuner stock,40tow,60tow,80econo, 120race.
Old Dec 9, 2006 | 10:07 AM
Fat Diesel's Avatar
Fat Diesel
You should see around 16 going up a hill at WOT. With a DP Tuner chip that number goes up about 10 psi on an early 99.
Old Dec 9, 2006 | 10:45 AM
ron's power stroke's Avatar
ron's power stroke
i agree..in my 80 econo go peddle all the way down im pushing 27 to 28 easly..stock im around 20...just cruising im at around 5 to 10 or so at 75 mph
