Leaking Fuel Filter
Old Dec 7, 2006 | 12:10 PM
dieselbogging's Avatar
dieselbogging
Unhappy Leaking Fuel Filter
Just recently my truck starting having a problem starting. I investigated and noticed that my fuel filter is leaking. I just put a new one on about 2 months ago because of this same problem and it worked up till now. The temperature is reaching -20 now. I pulled the filter off to check the o ring and it seemed fine. Any ideas???
Thanks
Old Dec 7, 2006 | 07:31 PM
KJLYPW's Avatar
KJLYPW
I've had my truck for two years, change fuel filters twice, and had to retorque the leaking suckers both times, after about two weeks, what a PITA, but once retorqued didn't leak again, use some oil or grease on the seals when youy install and torque them up good! LOL
Old Dec 7, 2006 | 07:38 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
But just be sure not to overtighten as this will make it leak also.
Old Dec 7, 2006 | 07:50 PM
dieselbogging
Is this common? I heard oil will swell o rings. This is my first year for diesels so im trying to absorb as much as i can about them.
Old Dec 7, 2006 | 10:17 PM
Dave Sponaugle's Avatar
Dave Sponaugle
What brand filter are you installing?
I use Purolator and never have any trouble with mine.
