Sponsored by: Auxito
Some questions on codes in general
Old Dec 6, 2006 | 08:46 PM
metal13x's Avatar
metal13x
Will the truck's computer clear the codes after you fix the problem that set off the code in the first place, or do you have to fix the problem, then bring the truck in to have the codes cleared with a scanner? If so, will autozone clear codes? For free? Or is that something only the dealership can do? After you fix the problem, is it possible to clear the codes yourself by simply disconnecting the battery for awhile to reset the computer, or is that a dumb idea?
Old Dec 6, 2006 | 10:14 PM
LxMan1's Avatar
LxMan1
After you fix the problem, Autozone should reset it for you. If not, you can unhook the battery for about 1/2hr to reset it. The only problem with unhooking the battery is that you will have to reset the clock, radio, etc.
