Inside door molding
Old Dec 6, 2006 | 06:11 PM
XylemXorro's Avatar
XylemXorro
Inside door molding
Anyone know how to properly remove that piece of moulding that is inside the front doors opposite the mirrors? It's verticle and looks like it's hiding two of the mirror mounting bolts. Much Love!
Old Dec 6, 2006 | 07:08 PM
afreemanmd's Avatar
afreemanmd
if you are talking about the black sail-looking thing, its really easy to pull off. Its only held in by two or three snaps. Just kind of 'roll' it off from one side to the other. I like to wedge my fingers on one side or the other and kind of pull it. Should come off pretty easy. To put it back on, just kind of place it where it needs to be and give it a whack with the palm of your hand, and it should clip back in.
You are correct, the other 2 mirror bolts are hiding begind the plastic, but you will have to peel back the foam sheet thing thing to get to them also. FYI, if you are taking off the mirrors, you will have to also pull off the door panel and speaker to get to the wiring harness. poke around in the forum and you will find tons of descriptions of how to do that, and I think there is even a gallery of pics of how to do it too.
Good luck!
Isaac
