Sensor Identification Help
Old Dec 6, 2006 | 06:08 PM
1Knight's Avatar
1Knight
What is the ICP and where is it located?
EBP location and how hard is it to change?
Any pictures would be helpful.
Old Dec 6, 2006 | 06:09 PM
1Knight's Avatar
1Knight
if this matters.....2003 6.0
Old Dec 6, 2006 | 06:37 PM
npccpartsman's Avatar
npccpartsman
It's back behind/under the turbo. ICP = Injection control pressure sensor--hard to change.
EBP = exhaust back pressure sensor. Drivers side left front of the exhaust manifold with a little tube going in the bottom and a 2-wire plug-in on the top.
Check out the 6.0L bible located in the tech section (the first thread of the 6.0l forum). It will show you the sensors and their locations.
vloney's Avatar
vloney
The icp (injector control pressure) sensor, is behind the turbo, change it underneath. The ebp sensor will be in front of the driver side head, its not too bad to change. The icp sensor will cause you to lose much blood.
Old Dec 6, 2006 | 08:51 PM
BowTieHatr's Avatar
BowTieHatr
am i the only one who changes the icp sensor topside?
Old Dec 6, 2006 | 09:13 PM
spikebee's Avatar
spikebee
Ouch!...Yes!!
