Transmission Question
Old Dec 6, 2006 | 02:29 PM
ksmith203's Avatar
ksmith203
59T7006
N 4
I believe this to be a 4 speed tranny by shifting through the gears. The N 4 probably should have been a clue as well. Does anyone know if this was a good transmission. It will connect with an eaton 2 spd rear end. I have two of these both say 59T7006 but one does not have the N 4 below it. I think it came out of a smaller truck. The N 4 came out of a 51 flathead 8 F6. The bolt patterns are the same. I want to use it with a 7HA motor which as most of you know is in the machine shop getting bored out. The one without the N 4 had the adaptor plate for the 226 flat 6 cylinder. What are the pros and cons?
Thanks Kevin
Old Dec 6, 2006 | 05:21 PM
barry's Avatar
barry
It's a 4 speed "crashbox" tranny.NO synchros. You have to double clutch it. You should be able to interchange them.
Barry
50 F-1
Old Dec 6, 2006 | 06:17 PM
ksmith203's Avatar
ksmith203
Double clutching should not be a problem. I grew up moving my dads semi all over the place. He said he had to do it and so did I. Other than no synchros was it a durable tranny? It looks clean inside with no broken teeth.
Thanks Barry
Old Dec 7, 2006 | 06:51 PM
barry's Avatar
barry
It's a great tranny. Bullet proof! You can grind the heck out of it and it will still be ok. It's a pain to shift when you've been spoiled by a synchro tranny. The rule of thumb is ... slow and easy... when shift it. Can't be in a hurry! I learned to double clutch on a 1943 GMC 6x6 with a clark 5 speed! You went slow and easy with that monster!
Barry
50 F-1
Old Dec 7, 2006 | 08:57 PM
ksmith203's Avatar
ksmith203
I will definitely take your advice when I get it on the road. Story has people on vacation now through the end of the year. I have alot of other things I can do so I told him not to get in a hurry on the motor. I just want to have it by the end of March to test out awhile before SuperNationals. My goal is to drive it down.
Thanks for the help barry
ksmith203
Nov 28, 2016 10:58 PM
whitley
Jun 6, 2012 08:29 PM
lm987
Jan 30, 2010 03:13 PM
ksmith203
21
Feb 4, 2007 12:04 PM
