d44 guru's
Old Dec 5, 2006 | 09:50 PM
84FB351's Avatar
84FB351
d44 guru's
i read somewhere not all 44's have a crush sleeve? is this true. i bought a solid axle out of a 78 150 and when i took the pinion out all i have that goes on the end is the shims, then the bearing, the slinger and the yoke. am i missing something or do you set up pre load with yoke nut torque and no crush sleeve? i just wanna make sure im not missin any parts. im not familiar with these smaller axles so any help or "insight" would be appreciated
Old Dec 5, 2006 | 11:18 PM
teds74ford's Avatar
teds74ford
I don't think any of the dana's had the crush sleeve, but I am not 100% sure about that. When I did my 44, it was like you said-just shims and the slinger.
Old Dec 6, 2006 | 10:06 AM
rebocardo's Avatar
rebocardo
It is a usually found on the Ford 9".
