suspension lift
1. Do they affect fuel mileage? How badly?
2. would this kit (http://www.roughcountry.com/ford_83-97_midsize.asp) work to replace the struts and shocks?
3. I don;t know much about lifts, or suspension kits... whats a good price, brands, etc...
4. I go to school in the UP Michigan- would it hurt my winter driving?
5. I am guessing it would help my off road driving sonsiderably, am I right?
6. The rear suspension makes the truck higher in the rear... leveling springs would fix that right? would the lift kit above fix that problem as well?
ok, enough questions to bug you all with...
I have General Grabber P265/75/R15 tires on the truck now. it has the 4.0 and is a manual 4wd auto hubs. There are less than 60,000 original miles on it... thanks for your help in advance..
2: Cant help you here, except to say that your truck wont have struts, it uses the twin traction beam setup, with coilsprings and shocks
3: Cant help you here either, all I know is that Skyjacker and JamesDuff make what are generally regarded to be awesome kits, they come at a cost though, a cost that you probably wont need to spend from the way you speak of your intentions.
4: Winter driving wont be affected by having a lift, just take your corners slower. The body will clear snow-banks easier, and make sure you have some good winter tires! Remember, the more rubber that hits the ground, the less grip you've got on the ice!
5: It sure will, but only in terms of body/frame clearance, the bigger tires will get your axles further from the ground and those pesky rocks and other such things that are out there to bust up your truck.
6: Not related to that kit in particular, but most lift kits will tell you the amount they raise the front and the rear of your truck. You want to find a kit that will raise the front by about 1.5"-2" more than the rear if I remember right
