Sponsored by: Real Truck
Tire help
Old Dec 4, 2006 | 02:44 PM
tadkins22's Avatar
tadkins22
Tire help
Hello all I own a 05 f-350 superduty, (Drw) But looking to put some new tires on. Wondering what the largest size I could put on with no problems. Current tire size is 245/70/17
Old Dec 4, 2006 | 02:48 PM
4DOORSR's Avatar
4DOORSR
The superduty section might be a better place to post this. I'm running 305/65/18 on my F150 and that is as big as you can go without a lift or leveling kit.
Old Dec 5, 2006 | 06:27 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Dec 5, 2006 | 06:57 AM
TwelveAlpha's Avatar
TwelveAlpha
First answer is it depends on the year, because the SRW 99-03 and the 04- current have a different suspension in front and the newer guys seem to squeeze a little more in there before they rub.
BUT.
You have a dually. Theres a spacing between the two rear tires that's going to have to be maintained. I dont have a dually, so I can't say a specific size, I'm sure you can fit height wise more than you have, probably up to a 33", but that affects the tread width as well, and you could end up with your rear tires against each other.
Old Dec 5, 2006 | 04:37 PM
tadkins22's Avatar
tadkins22
Right now it has a 245/70/17 I would like to go with 265/70/17 not much of a difference but don't want to spend a grand on tires I can't put on!
Old Dec 6, 2006 | 10:35 AM
jwd1475's Avatar
jwd1475
My 05 has 17 X 7.5" wheels with 265 70 17 as stock size seems the biggest tire for that rim width is 285 70 17. I Picked -up some Goodyear silent armour tires on E-bay but havn't recieved them yet. Hope to install them soon.
