Tire Question
Old Dec 4, 2006 | 02:17 PM
WillyB's Avatar
WillyB
Tire Question
I have a set of 30-9.50 - R15 tires on ugly black spoke rims and would like to run them on my 59. The tires are a good sturdy truck tire with heavy sidewalls and a aggressive tread. I would like to use a steel disk wheel that is as close to stock as I can come and stock hub caps.
First, am I right in thinking that the tires are too wide for the stock 5.5 inch wide rim?
Second, is there a steel rim that would work and hold a stock hubcap?
Old Dec 4, 2006 | 04:32 PM
Jag Red 54's Avatar
Jag Red 54
Clint, Stockton Wheel will make them with any center you want. I would suggest a smoothie so the brake dust stays on the inside of the rim. Jag
Old Dec 4, 2006 | 05:00 PM
arctic y block's Avatar
arctic y block
Same with Less Swab
Old Dec 4, 2006 | 06:31 PM
Huntsman's Avatar
Huntsman
I ordered a set of Stockton chrome smoothies last week. They custom make them to suit your needs based on bolt spacing and offset.
Old Dec 5, 2006 | 07:02 AM
GreatNorthWoods's Avatar
GreatNorthWoods
You should have a wheel with a minimum width of 7 inches for those tires and 8 inches would be preferable. You might try www.Petepaulsen.com for his Gennie wheels which are available with the 5x4.5, 5 on 4.75, or 5 on 5.5 pattern and they accept stock hubcaps. The 30x9:50s should work fine on the rear but I would not use them on the front unless you have PS or Popeye arms...
Old Dec 5, 2006 | 08:31 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I hope you have powersteering!
