instrument cluster problem
Old Dec 4, 2006 | 02:03 PM
glgreer's Avatar
glgreer
when starting engine after it has sat overnight all gauges max-out for a few seconds and than register the correct position. Any ideas??
99 eddie bauer 5.4
Old Dec 4, 2006 | 03:50 PM
davesexpedition's Avatar
davesexpedition
Loose connection, or a bad battery. I noticed after unhooking my battery for whatever reason, and hooking it back up after a while upon startup the gauges will do the sweep thing. Also happened after I disconnected my cluster to install my white faced gauges, then reconnected them, sweeped on startup.
Common consensus that I've read (because I actually think it looks kinda neat) is that this happens when the PCM is reset, ie electrical loss/failure etc.
Old Dec 4, 2006 | 04:24 PM
01silvergt's Avatar
01silvergt
That is a common indication that the battery is on its way out. Get a new battery.
Old Dec 5, 2006 | 08:03 AM
glgreer's Avatar
glgreer
Thank for the info
