Sponsored by: Auxito
4x4 problems need help!!!!!!!!!!!
Old Dec 4, 2006 | 09:44 AM
jsstanley's Avatar
jsstanley
I have a 1997 f150 and im having problem shifting out of 4 low I changed the switch and the shift motor what other problem could it be
Old Dec 4, 2006 | 09:54 PM
Racerguy's Avatar
Racerguy
When you shift it I assume you have your foot on the brake and the transmission in neutral?
Does it shift in and out of 4high ok?
Old Dec 5, 2006 | 10:50 AM
jsstanley's Avatar
jsstanley
yes it shifts ok in and out of 4 high but it gets stuck in 4 low
Old Dec 5, 2006 | 11:13 AM
amerimutt's Avatar
amerimutt
Look underneath to see if any debris or caked up mud is around the linkage, I had same problem it was hardened mud,
Old Dec 6, 2006 | 12:02 PM
jsstanley's Avatar
jsstanley
thanks my man but my truck is electronic shift and I dont think it has any linkage thanks
Old Dec 6, 2006 | 12:42 PM
Wilber15's Avatar
Wilber15
Check the voltage at the shift motor. If it isn't getting the correct voltage(e.i...damaged wires) it could stick from not enough power. I believe you also need to have the transmission in Neutral when you shift into and out of 4Lo....
Old Dec 8, 2006 | 10:36 AM
jsstanley's Avatar
jsstanley
thanks man i'll do that
