Differential Question :)
Old Dec 4, 2006 | 12:21 AM
BuffmanLT1's Avatar
BuffmanLT1
I have a 91 2wd 5spd Ranger Are the rear ends in these trucks the 7.5" units??? What gears come stock with rangers? and whare are optional. I was looking to at trying to pick up a limited slip unit to throw in the truck (dont care if it's used as long as it works it's the winter truck) for better winter driving. I know I have rear ABS. I see ebay has a few used and new limited slip units available. What specific one am I looking for Thanks
Matt
Old Dec 4, 2006 | 06:04 AM
wendell borror's Avatar
wendell borror
What engine does it have, if it's a 4.0, it should have an 8.8, gears could range from 3:08's to 4:10's. The stock ford lsd is a trac-loc, the best is a detroit tru-trac. The stock ford lsd is better than nothing, but not by much.
Old Dec 4, 2006 | 08:43 AM
BuffmanLT1's Avatar
BuffmanLT1
It has the 3.0 in it.
Old Dec 4, 2006 | 04:02 PM
BuffmanLT1's Avatar
BuffmanLT1
Ahh found the rear end tag. All I could read on it was 45 where the gear ratio is so Im pretty sure I have 3.45s Now ot find a limited slip unit
Old Dec 4, 2006 | 04:33 PM
ranger88a's Avatar
ranger88a
More than likely, it's a 7.5 3.45 ratio. Find a 8.8 locker 3.55 ratio and it will bolt right in place. You will have to change the speedo gear a tooth or two, but it should be fairly close.
Old Dec 4, 2006 | 06:56 PM
BuffmanLT1's Avatar
BuffmanLT1
how will an 8.8 carrier unit fit into the 7.5.??? I'd likely not want to set up a new pinion and gear set anyways...
Old Dec 4, 2006 | 07:03 PM
wendell borror
I believe he ment to swap the whole rear end, take out the 7.5 and replace it with the 8.8.
Old Dec 5, 2006 | 12:33 AM
BuffmanLT1's Avatar
BuffmanLT1
gotcha I was like 8.8 > 7.5. I'd rather just swap in a T_lok or something and call it good.
Old Dec 5, 2006 | 07:38 AM
ranger88a's Avatar
ranger88a
Sorry, I did mean swap the whole rear end. I did check into a lock, but I could get a whole 8.8 rear end used for the same money.
Old Dec 7, 2006 | 01:33 AM
BuffmanLT1's Avatar
BuffmanLT1
Ended up picking up just a standard Ford Limited Slip unit off ebay for agood price. I havent yet opened the differential cover on my ranger, but how is the rear ABS setup on these trucks? It stated that the carrier would work with rearends with or without ABS. do they have a reluctor on the pinion for the ABS, or is it something else???
Old Dec 7, 2006 | 11:45 AM
BuffmanLT1's Avatar
BuffmanLT1
Is there a difference between the open differential crosspin and the limited slip carrier crosspin? Thanks.
5. Slow
Jan 23, 2011 03:13 PM
richborru
18
Jul 18, 2007 03:32 PM
BuffmanLT1
15
Oct 26, 2006 07:40 PM
JustinH
May 27, 2004 08:02 PM
rallyXR
All Things Towing
Dec 26, 2003 11:56 PM
