20 degrees F! Exterior lock cylinders a bit stiff, clutch and shifter stiff (used gently as practical), truck sat all day until about 10 pm, then fired right up just the same as any other day. Quicker than that '03. Didn't really do anything special that should affect it that way other than about 1K miles on Mobil Clean7500 10w30 and the Schosche "platinum" neg batt terminal about the same time. Only bugger is work boots in the bed with a frozen cap lock. Have to get some de-icer early tomorrow. Oversights sure can be silly.
