Computer Chips & Tuners
Help Ecu Cal. Code
Old Dec 3, 2006 | 07:53 PM
dv_shane's Avatar
dv_shane
Help Ecu Cal. Code
Can Anyone Tell Me The Calibration Code Was Wiped Off My Ecu And Its Not In The Door Jam. Is There Any Other Way To Get The Code Or Do I Have To Buy Another Ecu?
I Thought That There Is A Good Scanner That Can Get It From The Ecu?
It Is A 1994 F-150 5.0, 4r70w Trans , Obd 1
I Bought A Diablo Delta Sport Chip And It Was In A Mustang Can I Just Put It In And See If It Works Or Will Bad Things Happen If Its Not The Right Code?
Thanks Dave
Old Dec 3, 2006 | 10:01 PM
ReAX's Avatar
ReAX
I don't think a 94 will comunicate with a scanner capable of asking for a clibration code. Your best chance is to pop the case on the ecm and see if it is written on a prom or board.
If the calibration is off, it could cause you injectors or timing to go screwy. I really wouldn't do it.
Old Dec 3, 2006 | 11:03 PM
ReAX's Avatar
ReAX
