59 ford 3ton engine conversion
Old Feb 25, 2002 | 08:41 AM
fordlowboy's Avatar
fordlowboy
hi
i'm wondering how you would go about putting a late 70's 400m in a 3ton 59 ford? thanks for your time.
Old Feb 25, 2002 | 01:06 PM
Earl's Avatar
Earl
Old Feb 26, 2002 | 08:24 AM
460 Joe's Avatar
460 Joe
Any way you can! There are several options. There are companies that sell motor mounts for swaps, there are solid motor plates, and the backyard bonus that I have used is to find a donor Ford car that uses a crossmember with mounts on it, cut it out, weld angle clips on each end and weld or bolt it to your frame rails. Don't forget a trans mount, bigger radiator, exhaust mods, carb linkage mods, driveshaft mods, and so on. Good luck.
